Coding Testing
main.rs
fn main() { let greetings = [ "Hello", "Hola", "Bonjour", "Ciao", "こんにちは", "안녕하세요", "Cześć", "Olá", "Здравствуйте", "Chào bạn", "您好", "Hallo", "Hej", "Ahoj", "سلام" ]; for (num, greeting) in greetings.iter().enumerate() { print!("{} : ", greeting); match num { 0 => println!("This code is editable and runnable!"), 1 => println!("¡Este código es editable y ejecutable!"), 2 => println!("Ce code est modifiable et exécutable !"), 3 => println!("Questo codice è modificabile ed eseguibile!"), 4 => println!("このコードは編集して実行出来ます!"), 5 => println!("여기에서 코드를 수정하고 실행할 수 있습니다!"), 6 => println!("Ten kod można edytować oraz uruchomić!"), 7 => println!("Este código é editável e executável!"), 8 => println!("Этот код можно отредактировать и запустить!"), 9 => println!("Bạn có thể edit và run code trực tiếp!"), 10 => println!("这段代码是可以编辑并且能够运行的!"), 11 => println!("Dieser Code kann bearbeitet und ausgeführt werden!"), 12 => println!("Den här koden kan redigeras och köras!"), 13 => println!("Tento kód můžete upravit a spustit"), 14 => println!("این کد قابلیت ویرایش و اجرا دارد!"), _ => {} } } }
fn main() {
let greetings = [
"こんにちは", "안녕하세요",
match num {
_ => {}
dead[0]=a
live[0]=b
dead[n_]:=dead[n-1]+c*dead[n-1]-d*live[n-1]
live[n_]:=live[n-1]-c*dead[n-1]
% https://github.com/GalAster/vscode-arc/blob/master/package.json
name = 'vscode-arc'
displayName = 'Arc Language Support'
description = 'Highlight and formatter for Arc Readable Configiration'
publisher = 'aster'
version = '0.1.2'
icon = 'logo.png'
engines/vscode = '^1.8.0'
[categories]
> 'Programming Languages'
> 'Formatters'
{repository}
type = 'git'
url = 'https =//github.com/GalAster/vscode-arc.git'
{scripts}
postinstall = 'node ./node_modules/vscode/bin/install && tsc'
build = 'yarn lint && ts-node syntax/build.ts'
pack = 'yarn build && vsce package'
lint = 'tslint **/*.ts --fix'
{dependencies}
vscode = "^1.1.33"
{devDependencies}
'@types/node' = '^11.13.6'
{contributes}
[^languages]
* id = 'arc'
aliases = ['ARC'],
extensions = ['.arc']
filenames = [ ]
mimetypes = ['text/x-arc']
configuration = './syntax/arc.configuration.json'
[:grammars]
* language = 'arc'
scopeName = 'source.arc'
path = './syntax/arc.tmLanguage.json'
* scopeName = 'markdown.arc.codeblock'
path = './syntax/arc.markdown.json'
injectTo = ['text.html.markdown']
embeddedLanguages = {'meta.embedded.block.arc' = 'arc'}
{__metadata}
id = '6267dad2-7d52-462a-a1ef-7e3da7378a7d'
publisherDisplayName = 'Aster'
publisherId = '3406b78c-f287-4619-8d82-7c97998693e3'
% This is a Arc example document.
% Using `%` starts line comment
*here is a markdown note*
**let's set some meta info**
*`$` means Unique*
- $version = 1.0
*`@` means Changeable*
- @align-comment = true
- @empty-line = 2
{literal.integer}
int1 =+99
int2 = 42
int3 = 0
int4 =-17
int5 = 1_000
int6 = 1_2_3_4_5
{literal.decimal}
flt1 = 0.
flt2 =-0.0_2
flt3 =+5_0.
flt4 = 3.1415
flt5 =-0.01
flt6 = 224_617.445_991_228
% infinity
sf1 = infinity % positive infinity
sf2 =+Infinity % positive infinity
sf3 =-INFINITY % negative infinity
% not a number
sf4 = nan % actual sNaN/qNaN encoding is implementation specific
sf5 =+NaN % same as `nan`
sf6 =-NAN % valid, actual encoding is implementation specific
{string}
char = `2`
singleline = "This is a string."
multiline = """
\b - backspace (U+0008)
\t - tab (U+0009)
\n - linefeed (U+000A)
\f - form feed (U+000C)
\r - carriage return (U+000D)
\" - quote (U+0022)
\/ - slash (U+002F)
\\ - backslash (U+005C)
\u1234 - unicode (U+1234)
literal = '''
\t - tab (U+0009)
\" - quote (U+0022)
\/ - slash (U+002F)
{list.inline}
arr1 = [1, 2, 3]
arr2 = ["red", "yellow", "green"]
arr3 = [[1, 2], [3, 4, 5]]
arr4 = ["all", 'strings', """are the same""", '''type''']
arr5 = [
[1, 2]
["a", "b", "c"]
arr6 = [1, 2.0]
inline = [
{ x = 1, y = 2, z = 3 },
{ x = 7, y = 5, z = 9 },
{ x = 2, y = 4, z = 8 },
[list.scope.insert]
> 42
> 'string'
> [true, false, null]
[list.scope.string]
- Apple
- Banana
- Cherry
[list.scope.dict]
* name = "Apple"
color = "red"
* name = "Banana"
color = "yellow"
* name = "apple"
color = "red"
% expand above syntax
{list.scope.expand}
insert = [42, 'string', [true, false, null]]
string = ['Apple', 'Banana', 'Cherry']
dict = [
{name = 'Apple', color = 'red'},
{name = 'Banana', color = 'yellow'},
{name = 'apple', color = 'red'}
{dict.server}
{^meta}
ip = [
$dict.server.alpha.ip
$dict.server.beta.ip
{:alpha} % child node
id = 10000
pw = "力微任重久神疲"
{:beta} % child node at same level
id = 10001
pw = "再竭衰庸定不支"
{dict.server.expand}
{version}
alias = 'v|version'
eg1.input = v|1.0.0
eg1.expand = {
major = 1u64
mino = 0u64
patch = 0u64
{DateTime}
ld1 = dt'1979-05-27' % Local Date
lt1 = dt'07:32:00' % Local Time
ldt1 = dt'1979-05-27T07:32:00' % Local Date-Time
odt1 = dt'1979-05-27T07:32:00Z' % Offset Date-Time
odt2 = dt'1979-05-27T07:32:00X'
{Regex}
ipv4 = re|(\^)?\s*([A-Za-z_-][\\/@A-Za-z0-9_-]*|".+"|'.+'|[0-9]+)\s*(@[A-Za-z]+)\s*(=|:)\s*
ipv6 = re|^([\da-fA-F]{1,4}:){7}[\da-fA-F]{1,4}$
{Embed}
table = csv```
a,1
